3 members (moparguy, JW51, RLB),
133
Mod | | | Forums66 Topics128,091 Posts1,056,390 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | https://www.farmoyl.com/portal/server.pt/community/1lubricants/569#I was at the local John Deere store today to pick up some corn head grease. They suggested using this product, much easier to put in than grease out of a cartridge. When you go to the link look to the right side for product information, then click on premium greases, then on the second page, Fluid Grease.
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I found a spatula and cake decorating bag were the ideal tools to get the corn head grease from the tube to the box. If it will pour it's too thin IMO.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | And if it won't pour then it will not lubricate the recirculating ball screw and nut. And that is why the factory service bulletin suggested something that will flow enough to do that.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Corn head grease does flow and does a fine job of lubricating a steering gear. I was just pointing out another option that is available. | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Have you ever tried straight STP? That is what we were told to use back in high school (early/mid 60s) by one of the mechanics in town. I've used it in several vehicles and it has always been fine. As far as I've seen it doesn't channel, leak (if you have a reasonable seal, that is), break down, get thin, etc. And it definitely sticks to everything in there. Just a thought. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Both the greases posted by don stocker and chadkiser meet the original NLGI 00 specification. STP might work without leaking much but it is much thinner than NLGI 00 self-levelling grease.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Stenns 00 Is yet another, used in CV joints and also available at your lawn mower repair shops. 00 grease is hard to find local sometimes if you're not in farm land.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Agree with you Tim, Don, Chad and Trucko', as I've posted a zillion time over the past decade, that I started out in high school as a greaser at a Chevrolet Dealership. We would top off a steering gear with the same grease we used in the rear axle and manual transmissions, hypoid grease in other words. The only reason the use of cornhead grease and fluid greases has taken on a life of it's own is because we don't have gravel roads and drive ways any more. Most people today have been domesticated to the point that they can't stand to have a puddle of grease or oil on the epoxied garage floor or driveway pavers. 60 years ago these vehicles were expected to leak some. There was a time when the new cars on display would have a drip tray under them, I know cus I cleaned up enough of them back in the late 50's.
Denny Graham A greaser still, in Sandwich, IL
Denny G Sandwich, IL
