2 members (baldeagle, Hotrod Lincoln), 71 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#1027141 05/08/2014 2:43 PM
My old tattersfield intake came to me with two Rochester’s. One of the carbs has a broken idle adjust screw in the throttle body that is not fixable. The setup is for a 216 that I’m putting on a 235. I have read that I need to use matched carbs and these Rochester’s are in nice shape for a rebuild. What makes them matched? Can I just change the throttle body? The # on the base of the throttle body reads 7004522c on both carbs. I’m guessing that I need to find that same # of throttle body. Carb body reads RF Rochester GM
Riding in the Passing Lane
A throttle body from another carb with the same size hole & mounting will work. The main jets & power valve spring need to be matched.
1972 Chevy c10 Cheyenne Super
