3 members (Nick in Manitou, TooMany2count, klhansen), 120 guests, and 4 robots.
Topics128,109
Posts1,056,240
Members48,437
#1026947 05/07/2014 6:12 PM
1 Offline
I installed a HEI in my Stovebolt and use 8 mm plug wires. It is a 12 volt system. It starts immediately and I have been through four sets of Plugs (10mm Champion, AC and NGK. The latest was Iridium by NGK. I have checked everything including the timing. Does any Stove Bolt'er have any suggestions to make to help me solve the Spark Plug life issues?
Normbc9
What is failing about the plugs? There is no reason I can imagine for the HEI system to damage plugs- - - -having that 50KV+ open circuit voltage available will fire a plug with the ground electrode completely removed if necessary, and if the plug is clean and gapped properly, the firing voltage is usually below 10 KV, regardless of what ignition system is used. Gap the plugs at .035"-.045" when using the HEI system.
This is odd. HEI's usually extend plug life.
My Blog
1 Offline
Thanks Jerry. The electrodes are worn down to the plug base. If I'm smart enough I'll post photo's.
Normbc9
If the center electrodes are eroding, it sounds like you're running a very lean mixture. Are the insulators snow white and blistery looking? What about carburetion? Anything exotic, or just a stock single carb setup?
1 Offline
It has dual Carter-Webers on a heated intake plus a set of headers. The plug tips are deep brown in color and the electrodes are almost invisible.
Normbc9
