| | | Forums66 Topics128,100 Posts1,056,178 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | in the block on the chevy 235 1949 i have there is a washer inside which i noticed when i pulled the distributor and it nearly fell down into block. I dont see one on the 1959 engine I have. did they eliminate that on that year ?? also i think the 49 has a later distributor as someone had already changed it to 12V flywheel /starter. how can i confirm it is a later distributor ?? earlier post replie said ok to use cast on the forged. thanks | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | One issue at a time, Washer between the distributor and block? Big flat washer looking thing? I am not sure what you have. Cast drive gear on a forged cam will wear fast. Forged gear with a cast cam will rear the cam also fast. Match the drive gear to the cam. Which distributor you have can be determined by the number on the label on the side of the dizzy. There is a Good post on the dizzy part numbers on here some where. I just can't remember where.
Steve H
| | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | i should have said top of oil pump?? there is a recessed washer on the 49 is the 59 the same ?? when i pulled the distributor on the 49 the washer almost fell to the side. thanks
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There should not be a washer on top of the oil pump. I have seen some pumps that look like they have a washer built into the top of the pump. Maybe you have one of these and the washer has come loose. Chevrolet sold as a replacement, for the earlier steel cam distributors, the distributor designed for cast came. I have not seen any abnormal wear by using this combo. I do not recommend going the other way around.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 101 Shop Shark | | Shop Shark Joined: Oct 2012 Posts: 101 | dave you are exactly right as mine definately has the washer glad i found out have to be careful putting dist out/in. thanks | | |
