4 members (HandyAndy, Jon G, 2 invisible),
148
Mod | | | Forums66 Topics128,087 Posts1,055,985 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 24 Apprentice | | Apprentice Joined: Sep 2007 Posts: 24 | I installed a new sending unit in the fuel tank and a new fuel gauge (12 volt), the gauge reads 1/2 full consistently, I replaced the fuel gauge with a new one from lmc and it reads empty consistently. What should be my next step to correct this? thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bobshollow,
Your profile says you have a '53 pickup, so that must be the rig in question.
If you do a search in this forum using the word "gas gauge", you will find all kinds of tests to answer some of your questions.
Your rig must have been converted to 12 volts already, as you have installed a new 12 volt gauge assembly. The gauge itself must be grounded in the dash, and the tank must be well grounded too. Properly grounding the tank usually involves a additional wire from a sending unit mounting screw to a good ground on the body or frame. Grounds make this system work properly.
Make sure the power side of the fuel gauge is getting a good 12 volts....no old voltage reducers should be hiding in this line.
I have seen folks here talk about receiving faulty gauges, as these are a real aftermarket specialty item, and QC is sometimes lacking.
Read some of the previous posts on this subject, verify that you have the proper power and the components are properly grounded, and come on back if all these lead to a dead end. Good luck.
Stuart | | | | | Joined: Sep 2007 Posts: 24 Apprentice | | Apprentice Joined: Sep 2007 Posts: 24 | Hello Stuart, thanks for taking the time to answer my question. I'm new to the forum so I probably should have done a "search" before posting. I'll try your suggestions and see what happens, I'm glad I'm not the only person with fuel gauge problems. thanks Dave | | |
