3 members (WICruiser, 2 invisible), 142 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
I have an electric fan mounted on the outside ( grille side ) of my radiator, set up on a thermostat switch set at 190F. Currently it is pulling air thru the rad and out the grille. This seems at cross purposes with standard fan which is pulling in the opposite direction ? Is there a way to reverse the electric fan wiring to push, or are the blades 1 direction only ?
1940 Chevy KC 1/2-Ton
britcon,
If you could reverse the motor, that would obviously make the air flow go the direction you want. Turing the fan blade assembly over won't accomplish what you want.
If the motor is a permanent magnet motor, it should be reversible by swapping leads. The very best scenario would be to find the manufacturer and give them a call...or ID the thing here, and maybe a member of the forum has "been there, done that".
Stuart
Can you mount it on the engine side so it will pull normally? I think most fan blades are directional, meaning you cant just reverse the motor and achieve the same cfm in the opposite direction. I could be wrong. Good luck.
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
I looked at some fans online. Some indicated that the motor was reversible, some didn't say.
A few with very 'curvy' fins indicated the motor was reversible, but that the fan too had to be flopped to keep the curves going the right way.
Stuart
Britcon,
One of the reasons folks use the electric fans is as a replacement for the stock fans blades. I've seen many engine where the stock blades were removed and a fan placed on the engine side to pull air through as normal. The electrict fan come in many sizes and many cfm.
However, you may not like the look of the engine without the metal blades.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Thanks for all the replies. The mechanical fan I have has Flexalite type blades and moves quite a bit of air. No room to install the electric fan on the inside face of the rad without removing the mechanical fan. Let me see how cool she runs in hot weather - see if I am worrying too much.
Most fan motors are permanent magnet; on these motors, if you reverse the electrical connections the motor will run in the opposite direction and the fan will then blow through your radiator.
