9 members (JW51, Gdads51, Otto Skorzeny, UtahYork, Rusty Rod, Ponchogl, Lonnie, Southerntruck, Cosmo), 282 guests, and 4 robots.
Topics128,089
Posts1,056,129
Members48,435
#1026882 05/07/2014 3:14 PM
Will a ford 9 in. Axle fit in a 1960. if not what rearend is the correct width to retro fit in the old beater... Im pushing 500 hp to it
That is 9 in ford pickup rearend
Not sure about a 1960, but if you measure your old axle, you can find widths of 9" if you google around. Width is one thing, then other is spring perch location, but those can be cut and re-welded. Emergency cables and brake lines should be pretty simple retrofit.
See sites like: http://www.therangerstation.com/tech_library/9InchAxles.shtml
R-Bo
1966 GMC 305V6 in the family
