6 members (MRMEROTH11, FAST55, 1955 1 Series, Hotrod Lincoln, greenie-reddy, Otto Skorzeny), 127 guests, and 1 robot.
Topics128,051
Posts1,055,768
#102678 09/21/2007 12:35 PM
Apprentice
Apprentice
I have installed a new 12 volt gas guage in the old truck . The previous guage was 6 volt with a resister connected to it. Here is my question . Do I need to remove the resister for the guage to operate correctly ?
#102679 09/21/2007 1:33 PM
If your system is 12 volts and you have installed a 12 volt gauge I would not think a resistor is needed in the supply line of your gauge.
#102680 09/22/2007 3:41 AM
You wont need the resistor, but you'll need to see what the operating voltage and Ohm range on your fuel tank sender is. Might work, might not, good thing is 12V replacment senders aren't all that spendy.
1956 GMC 370 dump " 'Tater "
1970 VW Volksrod "the Black Bomber"
2007 Chevy Avalanche
2020 Jeep Cherokee Trailhawk,
2005 Harley Davidson FLHTCUI
I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things.
But thats just MY opinion!
:P
#102681 09/22/2007 4:26 AM
The only difference in the sending units is whether they are 90 Ohm or 30 Ohm, voltage is immaterial. The gauge itself is the only thing that's voltage sensitive.
#102682 09/22/2007 5:01 AM
My wife thinks I'm insensitive and immaterial too! I wonder if I'm a sending unit? wave
Stuart
#102683 09/22/2007 5:19 AM
No, you're just a normal male with a normal wife if my getting the same thing from mine is a sufficient statistical sample.
#102684 09/22/2007 5:30 AM
Freq2002 is correct in that the new gauge is unlikely have the same Ohm range as the old sending unit and will not be accurate.
