1 members (CATMAN),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,935 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Looks like they painted the side access covers on my 59 Panel when the body side was horizontal and didn't have anyplace to paint small parts. Other side same thing. Looks like a "standard" procedure that year. Smoking (Paint) Gun
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | Yep. My '57 3105 inside wall has silhouettes of painting the lower wall access covers. I couldn't readily identify the other items. What do you think they are? Inner Wall
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | more likely just 'wedged' the covers in there so they could be painted when the rest was done and would be handy for installing, knowing there would be cardboard panels added to cover the sloppy workmanship  Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I guess the other items you see are the glue line (from a roller?) for the tar paper/cardboard. You can see some of the material in lower right of my pic. Bill's probably right about wedging since they are all even with a body line but there is no actual place to wedge unless I have a piece missing.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | notice the 'bars' that frame those recesses are painted, but with overspray all along them, and there are little tabs [where the cardboard is attached] right above each mark ... hang the covers from those tabs and as the painter sprays around the space he just jogs a bit to hit the covers .... the patchy black areas are where pieces of the sticky sound deadener tar paper was, same stuff as between the 'headliner bows', strategically placed to dampen the drumming resulting from large flat panels, placed after paint
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Good thinking Bill, I do see that each cover is in line with a mounting tab.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | please, dont ever tell Bill good thinking......lol Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
