7 members (Bill Hanlon, baldeagle, Otto Skorzeny, tonyt, JW51, gswbbc, 55shaker),
84
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | When I bought my '57 Suburban, it did not have a jack. The frame is really high under the truck, and I am looking for a simple jack for road-side tire change, i.e. not a floor jack! Anyway, even my floor jack barely reaches the frame, hydraulic bottle jacks do not either... So, my double question is: what does the stock jack look like? What do you guys use? Thanks
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You should be able to find a hydraulic bottle jack that will work. The center post on most of them is threaded and will add 4-6" of height to the jack. You can put it under the front or rear axle and should be able to get the tire off the ground so you can change it. | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Thanks, Don. I guess I should have mentionned that my truck has 4-wheel independent suspension, '77 Camaro in the front and '86 Corvette at the rear, so either lifting the chassis or lifting the differential in the back, the wheels still hang low and I need to lift a lot...
