2 members (78buckshot, Wheelie), 131 guests, and 2 robots.
Topics128,128
Posts1,056,358
Members48,441
I need new door glass in my '42 Chevy COE, can I use windows from a long hood cab? If yes what years interchange?
1942 Canadian 1.5t Chevy COE
42-46 are the same for the conventional cab (they have the metal frame around the glass). Someone should be along to tell you if a COE is the same, or call Jim Carter or another vendor, they should know.
My 46 GMC on Photobucket
The glass is all the same from 41 to early 47. I think they also fit 39 & 40 but im not 100% sure.
And im pretty sure that the door glass & windsheild are the same for a panel also.
A panel or suburban has the same door and windshield glass as a pickup. I'm still not sure on COE doors. I misspoke, 41-46 (and early 47) are the same as JeffL said, but 39 and 40 use larger door glass. The 41-46 had a slightly smaller window with a metal frame around them, because breakage was an issue for the 39-40 trucks.
Here's a tech tip: Door Windows 41-46
