1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 16 New Guy | | New Guy Joined: May 2014 Posts: 16 | I need new door glass in my '42 Chevy COE, can I use windows from a long hood cab? If yes what years interchange?
1942 Canadian 1.5t Chevy COE
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | 42-46 are the same for the conventional cab (they have the metal frame around the glass). Someone should be along to tell you if a COE is the same, or call Jim Carter or another vendor, they should know. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | The glass is all the same from 41 to early 47. I think they also fit 39 & 40 but im not 100% sure.
And im pretty sure that the door glass & windsheild are the same for a panel also.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The glass is all the same from 41 to early 47. I think they also fit 39 & 40 but im not 100% sure.
And im pretty sure that the door glass & windsheild are the same for a panel also. A panel or suburban has the same door and windshield glass as a pickup. I'm still not sure on COE doors. I misspoke, 41-46 (and early 47) are the same as JeffL said, but 39 and 40 use larger door glass. The 41-46 had a slightly smaller window with a metal frame around them, because breakage was an issue for the 39-40 trucks. Here's a tech tip: Door Windows 41-46 | | |
