Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (baldeagle, kades51, IHPWR, Southerntruck, farmallb, JW51), 65 guests, and 3 robots.
Topics128,005
Posts1,055,264
Members48,418
#1026162 05/04/2014 7:16 PM
Got a problem. I have a '49 6100 Chev yard & 1/2. I've replaced the harness, coil, distributor, etc. I've got spark to the dist and points, but I don't have spark at the plugs. I've tried the short cover and rotor and the tall ones. All 12v now. Any advise? My '49
ssgintx #1026174 05/04/2014 8:53 PM
3B Offline
Hy ssgintx, do you have another coil you could try? A bad condenser can cause an intermittent or no spark situation as well, hope that helps.
ssgintx #1026181 05/04/2014 9:12 PM
Sir Searchalot
Sir Searchalot
Main wire from Coil tower to Dizzy tower (secondary) is bad? New coils, rotors and caps can be bad right away. Replace ALL plug and dizzy wires. Check dizzy ground and other vehicle grounds. What does "spark to dist" mean? What did you specifically test, what did you see?
ssgintx #1026185 05/04/2014 9:23 PM
Batamos, I watched the points spark as I cranked the eng. I guess I shoulda said "fire" to the distributor.
3B, I've tried two coils and two condensors.
ssgintx #1026202 05/04/2014 10:51 PM
OK, you have spark at the points and or current flow through the points to ground. Replace the coil wire and see if that is why you have no spark at the plugs. If not the coil secondary side is bad. MIKE
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
ssgintx #1026208 05/04/2014 11:29 PM
Did it work before you did that work?
Did you remove/reinstall the distributor for any reason?
With the pointer on the ball where s the rotor pointing?
ssgintx #1026234 05/05/2014 12:42 AM
Take the problem in pieces.
You visually have sparking at the points, good. Clean spark is good. A spark that is ragged, seems to explode out of the points, bad condenser.
Now test the spark at the distributor end of the coil wire.
If there is no spark there, replace the coil wire or test with a piece of sold wire for spark at the coil tower. Make your sure your test has a GOOD ground.
No spark from the coil is a bad coil.
Spark to the center of the dist. cap and nothing to the plugs - rotor, cap or spark plug wires.
Electricity follows rules. If your coil creates a spark, it has to go somewhere.
ssgintx #1026280 05/05/2014 3:35 AM
DADS50, It ran before I started my restore. The distributor is new, I just replaced it thinkin' it was my problem. I got the cap and rotor at the same time, same supplier. When the pointer is on the ball, the rotor is pointing at 1...about 1 o'clock.
Jim I'm going to start from scratch and test everything again. Maybe some of the stuff I put on is not good and I'm not seeing it.
Thanks everyone, I'll get back to you
Steve
