0 members (),
120
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Swapped out my 283 for a stock 350 crate engine. Had to pull it out to balance at 1800 miles. Nothing else changed or modified. Starts, runs fine, gets up to temp(180 deg.)while driving, after about 5 minutes it starts to bog, and then starts to backfire when ever I try to get into it some, and keeps getting worse. Will cruise, but nothing more. It was a year before it got back into the vehicle and restarted. I thought maybe it was running out of gas and causing a lean situation. Checked fuel flow from tank, new fuel filter, new pump. Carb looks clean inside. Up untill it starts to act up, it will do what ever you want, so I kind of ruled out mechanical issues. Other than the balance issue, it run fine before, and nothing has changed. I am running an Edelbrock Performaer carb, and Petronix in the distributor. If it was the carb, why start then. I knew I was going to tear it down, so I run a tank of Marvel Mystery oil thru it , and then topped it off and added some more. Can't imagine that would affect anything.Any suggestions are greatly appreciated. Thank you for your help. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Take the gas cap off for a few minutes and see if that makes a difference. Could be stopped up enough now that it is letting the fuel pump create a vacuum on the gas tank. If so then with the cap off it should continue to run.
Another thing may be the coil getting too hot. How long does it have to set before it will restart and run?
When it acts like this check the spark to the plugs to see if it's bright blue. If not then something is failing in the ignition system.
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I have a seperate hose that vents the gas tank, but I will check to see if it is open. The motor does not stop running, it will run alright in "cruise mode", but when ever I try to get agressive on the throttle, is when it is not happy. Before it starts acting up, I can floor it with no problem. I am driving it currently with the hood off, so I can't imagine it is a vapor lock type of thing. I thought about the coil, but have not checked to see if it's getting hot. Thanks for your reply. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Loosen up the exhaust pipe ahead of the muffler. The symptoms you're describing are classic for an exhaust system restriction such as a clogged muffler or catalytic converter if you have one. Another diagnostic procedure involves connecting a vacuum gauge to a source of straight manifold vacuum such as the brake booster line or the transmission modulator and hold the gauge down with a windshield wiper so you can watch it as you drive. When the bogging-down symptoms begin, the vacuum will drop to nearly zero and stay there anytime you're trying to accelerate. Loosen an exhaust pipe flange somewhere ahead of the muffler and see if the performance improves. Jerry
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | FWIW.. I had a '70 Nova back in the mid 70's that exhibited similar symptoms to what you are describing.. it was a cracked distributor cap. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I vote coil also, I would think plugged exhaust would show up right away, not after five minutes.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Cracked Dizzy cap... I forgot about that one (and it was only 5 years ago) but yeah that would do it too. It seems electrical to me whatever it is.
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | A new Distributor Cap was the first thing that I tried, no help. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | All the things mentioned above. One step at a time. Do something, like the dist cap, then test. Make a list and go through it. Add items as needed. Add this one just for kicks, Vacuum leak. So far: 1, Vent at tank. 2, Coil. 3, Cap, done. 4. Exhaust restriction. 5,Fuel pump. You get the idea. One step at a time. Let us know what you find.
Steve H
| | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | If nothing else shows up, try pulling the pertronix and put in points and condenser.
By the way, is the backfire through the exhaust or through the carburetor?
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | It mainly backfires thru the carb, but if I get on it hard, it does both.
tried dist cap, nothing fuel filter, nothing fuel flow from tank, I can fill a 2 pound coffee can in about 20 sec. new fuel pump, nothing took out jets, metering rods etc, clean exhaust flowed fine when I took motor out, unless theres a mouse in there, but I wouldn't think that would change with time or temp. I think I have another coil, I can stick it in and try it. My fuel line is all hard plumbed, except from frame to pump, which is only a year old, so I don't see any kind of a fuel line collapse issue. Thank you for your input. I'll keep you posted. | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | Venting the exhaust only involves loosening two or three bolts at a manifold flange- - - -might be worth a try before you reject the idea, as I've encountered the problem numerous times over the past 40-something years. Jerry
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Through the carb is usually a lean condition. I've seen a few problems with the eddy carbs. Check for leaks around the intake and carb.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I always thought a back fire was usually electrical and not fuel but what do I know.....I had a mallory on my 235 and the truck would act crazy at times.. it would bog down, then run fine for awhile, then at hiway speed it would drop down to almost nothing and start up again, it would sometime back fire, etc, but ended up being in the electronic module.... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | 1st choice would be the already mentioned clogged exhaust. I've seen it on a couple occasions. IN both case the engine would start and idle fine but cough,backfire and miss badly when accelerating. Both were 80's model SBC's....
2nd swag would be one or more valves are too tight and once the engine warms up they aren't closing fully.
Good luck Dave | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Well, it turned out to be the coil. At least I didn't have to start tearing into things inside. Thanks everybody for your help and input. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | What coil were you using? I've melted a brand new msd blaster3 on initial start up. Sometimes ya get faulty parts. Glad you found the problem. I now run a blaster2. No issues in 14 years.
Msd 6al - 7000rpm pill Blaster2 coil Msd boost timing master Msd billet distributor 10mm Taylor wires
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | It was a Petronix coil, worked fine for 6 years, and someting happened while it sat for a year waiting to be put back in. New one is the same thing, works fine. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Thanks for the reply. Happy motoring
