9 members (sron48, rfs56trk, Mike in Sycamore, Nick in Manitou, Otto Skorzeny, Bill Hanlon, Charles in CA, 2 invisible), 99 guests, and 3 robots.
Topics128,136
Posts1,056,745
Members48,454
#1026002 05/04/2014 12:32 AM
Hello all,
My oil dipstick tube has worked it's way free from my engine. When I try to pull my dipstick out the tube comes with it. Has anyone had this issue? Any ideas on a fix? Would something like thread locker work or will the heat melt it?
Thanks in advance
If you GENTLY squeeze the engine end to slightly egg shape it will fit tighter. Engine heat won't bother thread locker or if in doubt use sleeve locker.
Evan
Evan,
Thanks a lot, I will definitely try it out.
I never even knew there was a sleeve locker.
http://www.henkelna.com/product-search-1554.htm?nodeid=8797924524033
Angelo
