| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 29 | i have a 1950 chevy pick-up mounted on a 1985 half ton pick-up chassic i need to know if any one makes the original looking hub caps that fit the wheels on the newer running gear thanks Bob B | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Bob, Check with these folks, made me a set of 47 hub caps to fit ralley wheel. Good luck Jim http://www.thewheelsmith.net/ | | | | | Joined: Jan 2010 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 29 | thank you jim i will check them out Bob B | | |
