6 members (Jon G, 60steve, GradyB, SmalltownTRKGuy, Wayne67vert, 78buckshot), 119 guests, and 4 robots.
Topics128,204
Posts1,057,290
Members48,467
A couple of the boards in the wood bed of my 52 1/2 ton have rotted out. The rest of the boards seem to be in good shape. I just noticed that the bad spot is directly above the muffler. Actually I had just parked the truck and was sticking my hand through the hole in the bed, and I could feel the heat from the muffler. Hmmm.
Could the heat from the muffler have caused this? I searched the forum and found some posts about heat shields above the rear axle. My muffler is right behind the driver's seat. I don't think it is real close to the bed, but I haven't measured it. The bed appears to be oak and was replaced a previous owner, so I don't know how old it is, but at least 10 years old (probably more like 20).
Has anyone else had this problem?
My dad always told me, "Don't force it, get a bigger hammer".
Is you muffler strapped to the muffler bracket/hanger that is attached to the frame?
Tail pipe heat shield that you referred to?
I would think that the heat from the muffler would help to remove any moisture from the wood, maybe in your climate that's drying it out too much though?
My 46 GMC on Photobucket
I agree that if anything, the muffler would dry out and help preserve the wood. I think the left front portion of your bed was the lowest spot wherever the PO parked the truck, and the position of the muffler is just a coincidence. If the bed was replaced with red oak, that species is not very rot resistant and if parked outdoors I would expect advanced degradation after 10-20 years.
Lots more pictures
I looked under my truck today. I don't have that muffler bracket Tim mentioned. The muffler is several inches below the bed; much lower than the exhaust pipe as it goes over the rear axle. I guess I'll just chalk those rotted boards up to old age.
Thanks for all the replies.
