| | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 47 | Hi guys!
Can anyone recomend a vendor for a master cylinder for my 1958 Chevy 2 ton,
thanks for you help!
Harrydale | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I got one for my 54 1 1/2 ton from my local NAPA several years ago. From what I've read all NAPA's aren't created equal, guess maybe I'm lucky. John | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy harrydale, could you tell us the series designation for your truck, and whether or not it is an air or vacuum over hydraulic brakes? | | | | | Joined: Feb 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 47 | Well...............I'm not sure. Its a '58 2 ton 6400H With a Hydroboost. I'm thinking it must be vacuum over hydraulic. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Harrydale, Several listed on Ebay. Ebay Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy harrydale, the standard master cylinder for a 58 6400 with "Hydrovac" brakes is a 1 1/4" bore Raybestos p/n MC21698 RockAuto- Raybestos p/n MC21698 $125.79, this is a new cylinder Napa- p/n NMC M21698 $187.20 this is a new cylinder Napa- p/n NMC P21698 $102.60 this is a rebuilt cylinder hope that helps. | | | | | Joined: Feb 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 47 | thank you 3B that helps greatly!! | | |
