| | | Forums66 Topics128,162 Posts1,056,943 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 5 New Guy | | New Guy Joined: Dec 2009 Posts: 5 | Has anyone tried the trailblazer SS or Colorado frames under these trucks or know how close they are to fitting I just found out last night I get to help my dad redo his 1954 3100 he said he'll take care of the body but the frame is on me. if it would work it would be sweet having the V8 already and being all wheel drive | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A quick word of warning if you do go ahead with using the Trailblazer frame; Plan on rebuilding the front suspension. Trailblazer, along with its GMC/Oldsmobile/Buick/Isuzu/Saab relatives, are known for wearing out lower balljoints and outer tie rod ends.
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I think doing a chassis swap on anything would require some sort of suspension rebuilding, let alone a 60 year old truck front end.
S10's weren't really known for having trouble free front ends either. Weak ball joints and idler arm.
I had 180,000 miles on my Trailblazer before I needed any suspension work. I replaced the outer tie-rods, the strut arm bushings are worn, but I'll fix that another day. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Agreed. Just wanted to pass along known trouble spots on the chassis, I've changed out more balljoints in those, as well as S10s, than I care to count  . In fact, I actually am going to need to put at least a pair of uppers in my foul weather '85 S10 4x4, it'll be the second set for it.
