4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#1024638 04/27/2014 9:24 PM
Ive been looking all over this forum and on the internet on Booster upgrades. I am planning on using a 7" vacume brake booster with a dual MC. In theroy it should work but I would like to know for sure? I have a 51 chevy with a 2 speed rear end. the MC has a 1" bore. Will ths setup move enough fluid to the rear Wheel cylinders? They have two per side. Thank you all for your help
3B Offline
Hy tomc9770, welcome, as a general rule I would not install a master cylinder with a bore smaller than the original master cylinder, as you did not tell us what series/year truck you are working with we can only guess what size bore your truck originally came with. One note of caution with the brake kits, make sure the master cylinder you purchase is for the type of brakes you have, drum/drum for drum brakes, disc/drum for a disc drum setup, and disc/disc for an all disc brake setup, any system with the same type of brake at all wheels should not require a compensating valve, hope that helps.
I believe it to be a 6400. The vin buster won't work on my computer I tried several times. The vin is JEA1153162. Thank you all
Re-check your vin number, I think you may have some incorrect information that you are typing in. It would not work for me either.
3B Offline
Hy tomc9770, I think that number might be an engine serial number, there should be a plate somewhere on the cab with the model/series info on it, check around.
JEA1153162
JEA = 1951 6000 series with 235 engine (Flint, MI assembly plant)
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
The vin on the registration is wrong I just checked the vin tag on the truck and that reads 2UWK10562. Thank you
3B Offline
Hy tomc9770, according to the VIN buster your truck was built at Tarrytown N.Y. in November 1951, it is a 6400 2 ton with a 161" wheelbase. That truck had a master cylinder with a bore of 1 1/4", and that is the minimum size bore I would use on any new master cylinder I installed on that truck, hope that helps.
Thank you all for your help I found a few master cylinders with a 1 1/4" bore later model C20s I'm hoping it will fit on universal 8" power booster if so I should be in business.
