5 members (52Carl, RLB, Bill Hanlon, fonz8261, JoergK.), 101 guests, and 6 robots.
Topics128,192
Posts1,057,228
Members48,465
Just took receipt of a 53 3/4 ton last week- lots and lots to do to get it roadworthy again- this will not be as quick as the 64- that's for sure!
Anyway- I put in a rather large parts order and as I wait for it to arrive I removed the bench seat to be cleaned up and re-installed- I soaked the tracks in evap-o-rust to get rid of the surface rust- and now they are back together, looking good, and ready to be painted. Before I re-install I was going to hit the bearings and wheel/ tracks with some lube. Then I thought about all the crumbs/ crud/ and seat fiber dust that was under that seat-( clean for now ) if I hit the tracks with lube do I run the risk of future crud sticking to the grease and gritting up with works? I didn't notice any factory residue in the tracks- so I'm unsure if these ever were meant to be lubed or not- any feedback would be appreciated. Thanks! It's good to be back into the thick of things again.
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
I lube mine!
Yes lube the pulleys and lever pivots with oil and the track and
balls with a chassis grease. Some use Lubriplate but I've found
that it dries out over a relatively short time and that grease
last longer.
DG
Denny G
Sandwich, IL
I'd use dry graphite
excellent! "to lube" it is! Thanks guys- looking forward to getting my hands dirty again- anybody use superlube? I was considering that- I use it for metal on metal parts in the pinball machines I work on- doesn't dry out ( as far as I have seen) and stays where you put it-
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Moderated by  ndkid275, Phak1
