2 members (Frank50, Kilted54),
71
Mod | | | Forums66 Topics128,189 Posts1,057,222 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | Just took receipt of a 53 3/4 ton last week- lots and lots to do to get it roadworthy again- this will not be as quick as the 64- that's for sure!
Anyway- I put in a rather large parts order and as I wait for it to arrive I removed the bench seat to be cleaned up and re-installed- I soaked the tracks in evap-o-rust to get rid of the surface rust- and now they are back together, looking good, and ready to be painted. Before I re-install I was going to hit the bearings and wheel/ tracks with some lube. Then I thought about all the crumbs/ crud/ and seat fiber dust that was under that seat-( clean for now ) if I hit the tracks with lube do I run the risk of future crud sticking to the grease and gritting up with works? I didn't notice any factory residue in the tracks- so I'm unsure if these ever were meant to be lubed or not- any feedback would be appreciated. Thanks! It's good to be back into the thick of things again.
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes lube the pulleys and lever pivots with oil and the track and balls with a chassis grease. Some use Lubriplate but I've found that it dries out over a relatively short time and that grease last longer. DG
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Mar 2012 Posts: 156 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 156 | excellent! "to lube" it is! Thanks guys- looking forward to getting my hands dirty again- anybody use superlube? I was considering that- I use it for metal on metal parts in the pinball machines I work on- doesn't dry out ( as far as I have seen) and stays where you put it- | | |
