| | | Forums66 Topics128,034 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | Are the headlight bezels or trim rings on my 46 chevy 3/4 ton stainless steel? I ask because they are the only part of the buckets that aren't rusted. The bezels on my 1 1/2 ton are completely rusted out and it is the same year truck and all original. thanks, lane
sweetpealane
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Check with a magnet shouldn't be magnetic if it's SS. However, some SS is magnetic so look at the back side of the rim, if it was plated you will see discoloration where the hangers were placed during the plating process. dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | thanks, denny ... will do lane
sweetpealane
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I had a set that were rusted right through, but they were also painted (may have been earlier rings). I believe the 46 rings are supposed to be chromed steel but I'm not 100% sure. | | | | | Joined: Oct 2013 Posts: 97 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 97 | I thought they should be chromed steel too ..... I tried Denny's idea with a magnet and they proved [at least in my mind] to be stainless ..... in addition, there were scuffs or rough places that had no rust at all while everything else in and around the buckets were rusted to 'high heaven' ..... now I'm hammer and dollying out the dings so they can be placed back on the refurbished buckets ..... living in south Louisiana everything that has been around this long seems to be rusted out .... thanks everyone for your feedback [oh, and the idea of using Barkeeper's Friend to polish stainless I saw somewhere on the bolt this week makes this a cheap, money-wise anyway, repair .... having pretty good luck hammering the dings in the stainless lane
sweetpealane
