0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | $800 to do away with support rods? BOTH out of stock? I don't even have indoor plumbing or a color TV.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I fail to see what they've done to add the stiffness that allows for removal of the support rods. Maybe I'm missing something. Those Bitchin' products are always pricy, I don't think they're worth it IMO. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm trying to figure out what's different that make them more rigid also.
The inner fender skirt may be of a heavier gauge steel? Maybe bent in a manner that it's structural?
They claim you can use the inner fender skirts with the oem rad support with "minor" trimming.
I've seen the same product in a few other catalogs also. I can't really see what's improved.
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | I can't really see what's improved. Like most other P.T. Barnum specials- - - -they improve the manufacturer's profit margin! Jerry
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I'm trying to figure out what's different that make them more rigid also.
I've seen the same product in a few other catalogs also. I can't really see what's improved. It's only 18 gauge, that's not thicker than OEM. | | |
