| | | Forums66 Topics128,078 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Trying to improve visibility on my 46 tail & stop lights. It is a 6V system. Will a 12V bulb burn as bright using a 6V system? Given the same CP will a 6V bulb be better than a 12V or visa versa? Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Trying to improve visibility on my 46 tail & stop lights. It is a 6V system. Harold Use a #81 for your tail light and a #1129 for the brake light. You will have a brighter tail light than a 12V #1157 and a brake light nearly as bright as the #1157. Using a plastic lens is good advice. Also paint the inside of the housing with gloss white paint. My 6V '38 on the left with my modern 12V pickup on the right.
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Thanks for the advice guys and the reference to your conversion to LED's Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2014 Posts: 18 New Guy | | New Guy Joined: Jan 2014 Posts: 18 | I should add that Tiny's solution is the cheapest and easiest.
The reason I went LED was so that I could use my parking lights as blinkers with an amber light that could be seen during the day. LEDs are the only way I could find to solve that problem. But once you start ordering 6v LEDs from china and swapping out your blinker module to support LEDs, it makes sense to swap out the tail lights as well. | | |
