4 members (Otto Skorzeny, Hotrod Lincoln, TUTS 59, jmoore), 138 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
#1023828 04/23/2014 10:04 PM
Trying to improve visibility on my 46 tail & stop lights. It is a 6V system.
Will a 12V bulb burn as bright using a 6V system?
Given the same CP will a 6V bulb be better than a 12V or visa versa?
ohwell
Harold
Harold
Harold46 #1023834 04/23/2014 10:32 PM
I
I Offline
A 12V bulb, powered by 6V will be much dimmer than a 6V bulb of the same wattage.
If you want to improve the tail lights, use plastic lenses and get some 6V led bulbs.
Here is what I did:
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=1001454
Harold46 #1023837 04/23/2014 10:54 PM
Ex Hall Monitor
Ex Hall Monitor
Harold
Use a #81 for your tail light and a #1129 for the brake light. You will have a brighter tail light than a 12V #1157 and a brake light nearly as bright as the #1157. Using a plastic lens is good advice. Also paint the inside of the housing with gloss white paint. My 6V '38 on the left with my modern 12V pickup on the right.
Thanks for the advice guys and the reference to your conversion to LED's
Harold
Harold
I
I Offline
I should add that Tiny's solution is the cheapest and easiest.
The reason I went LED was so that I could use my parking lights as blinkers with an amber light that could be seen during the day. LEDs are the only way I could find to solve that problem. But once you start ordering 6v LEDs from china and swapping out your blinker module to support LEDs, it makes sense to swap out the tail lights as well.
