2 members (porsche, MickeyP), 124 guests, and 1 robot.
Topics128,051
Posts1,055,767
Hi All,
I am looking for info. on how the remove my heater core from my 1956 Chevy suburban? hoses weren't connected when I bought it and I am thinking it leaked on previous owner. I can't find any literature on 55-59 deluxe heater assembly and I would like to remove it to have it inspected/ fixed.
Thanks much...
Doug
Go to this link, find your manual for step by step instructions. Best of luck!
http://www.oldcarmanualproject.com/
1946 1/2-Ton Chevy
THANK YOU!!! guys...
doUg
' Offline
Heater Core Rebuilder
Web Site:
http://www.classicheaters.com/homepage.html
GP
1954 3600
Now cruising in
The Passing Lane
Douger,
I made this post when doing mine. Maybe it will help.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=133480&Number=922032
Dave
Doug, mine was like yours. The P.O. had disconnected the heater hoses. Turned out my core was fine, it was the control valve that was bad and leaking.
I tested my heater core using a section cut out of a bicycle tube. Leaving the valve stem in and clamping the tube around the core pipes. Then submerged it in a tub of water and added air pressure to the tube.
No bubbles from the core, but the valve was leaking bad.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
I'll back that up what 'Old GMC Gold' said, plus I tested mine hooked up to the hot engine with core on the fender. Didn't leak, but 3 miles down the road the valve diaphragm let loose. Replace the diaphragm even if it doesn't leak. The old rubber hardens with time then cracks, a matter of not if, but when. $10.00 at NAPA for the part.
