| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I have Pioneer speakers part # TS-A4103. They have one small spade connector, and one larger spade connector to wire up to, but they are not marked as pos. or neg. I couldn't find any information on the internet. Any help with this would be appreciated. I would like to wire them right the first time.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Brian, Contact Pioneer with your question. Contact form below. Pioneer Contact Form Harold
Harold Is a restoration ever finished? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't worry bout the polarity to your electrical system Brian, just hook them both up the same way. I believe they do that so the two are in phase to avoid one canceling out the other at times.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Harold and Denny thank you for your replies. I e/mailed Pioneer, we'll see what they have to say.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | In case anybody is interested, I got a reply back from Pioneer today. The bigger spade is + and the smaller is -.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's mainly so you get them both as I mentioned earlier, in phase. The individual speakers will function in either polarity but as a pair they just need to be both connected in the same way. Try it and see for your self, you taint gonna hurt anything.
dg
