2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#1023067 04/20/2014 4:56 PM
Good Morning,
Does anyone know a good trick to removed the heater knobs from a deluxe heater control in a 66 c10? Is there a way to remove them and salvage them for re-use?
Thanks and Happy Easter!
You might want to try heating them with a blow-drier and then using pliers to pull them off.
Of course you would want to wrap a small rag around them to keep from leaving plier marks on them.
They don't cost much to replace if you don't succeed
Bob
Well, I succeeded at breaking off two of the control arms where the metal inserts into the plastic knobs. Anyone have any good suggestions to repair the control arms or any idea where I can find replacements? Thank you.
check the links section and investigate vendors near you, any of them that cover the years will have them
