| | | Forums66 Topics128,268 Posts1,058,379 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I thought I would post this in case anyone had problems with their straight six running rough (in my case a 1955 first series 235).
My engine vibrated a lot but would start right up. It sucked a lot of gas, I knew this because the truck was not on the road yet and my gas tank was an "IV" bottle. I figured the carburetor must be overfilling and dumping too much gas into the intake.
I ordered a carburetor rebuild kit and replaced the accelerator pump, the float needle and seat, and one gasket. The truck seemed to run better and I figured I might as well set the timing. Well I could not get the light to trigger on the number one cylinder. I thought maybe the light was bad and then I realized that the number one cylinder wasn't firing. I removed the distributor cap and found it to be horribly worn on the inside. I had an old spare and put it on. The truck ran pretty darn good :-)
I thought for good measure that I should get a new cap. You can get them at Autozone for about $9.00. When I put the new cap on I was amazed at how smooth the engine was! (the rotor, points, and condenser were already new). It is really quiet too.
The moral of the story is if your engine is running rough check to make sure the float is shutting off the gas and that the float level is set correctly and by all means get a new distributor cap. It can make a huge difference :-)
Joe
1955 First Series 3100
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Thanks Joe. Was that a Rochester 2 bbl? Any tricks on that rebuild kit or pretty straightforward? I'm guessing the needle valve adjustments or in the shop manual or the kit?
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | It was a Rochester 1 bbl. The kit has a lot of little parts for a bunch of different carburetors but the only things I found useful was the accelerator pump and the float shut off. Float height is 1-9/32 closed and 1-3/4 open as measured from the top half of the carburetor (with gasket) to the top of the float. Its also in the instructions that come with the kit.
Joe
P.S. yes the kit was real easy
| | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Plug wires are also very important.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Mendonjo, did you ever get to check the timing??? Was going to recommend fine tuning that timing with a vacuum gauge. You will be surprised how much better you can tune your motor. | | | | | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | Geez, It's been 10+ years since I've touched my plugs, wires, cap, points. Maybe one of these days.....when it quits running so well. :-)
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
