| | | Forums66 Topics128,084 Posts1,056,085 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | When using a one wire alternator what is the preferred method to protect the circuit? I know that newer vehicles are using a high amp fuse that bolts into a holder. I have seen others use a large maxi fuse and holder with a 50 amp fuse. I know that in the 70's fusible links were used to protect circuits. Thanks
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | No special fuse on my '38. Just the normal fuses, 25 amp whole car fuse plus individual fuses on each device.
| | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | Fusing an alternator is almost a waste of effort. The stator is self-limiting as far as maximum current output goes, and about the only way to make an alternator short out is to connect a battery or a set of jumper cables backwards. If you choose to fuse the alternator, use a fuse that will carry its full output plus 10%. A 55 amp alternator would need approximately a 60 amp fuse, etc. 70 amp alternator- - - -80 amp fuse. Remember- - - -fuses protect the wire, not the end item in the circuit. A fuse will not prevent a component from shorting out or wearing out; it only keeps a wire from burning. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A fuseable link wire works best on an alternator. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
