4 members (TexasA&M48Truck, MRMEROTH11, Wickedbass, Gdads51), 68 guests, and 2 robots.
Topics128,066
Posts1,055,874
Members48,428
#1023879 04/24/2014 1:42 AM
I am currently painting my 54 3100 ocean green with pearl interior but we are confused about the inside of the doors, the door jams and hinges. Should they all be green?
Gary U,
The cab exterior color ends at the edges of the exterior sheet metal.
What this means will become apparent after you you run your hand over exterior sheet metal until you reach each inside opening/transition.
Ocean Green is a very nice color.
Pearl Beige is the name of the pickup cab standard interior color.
Good luck with your project. Please post links to photos.
Is the vertical section at the floor between the firewall and the doors pearl? So when I open the door the edge will be pearl?
