2 members (Hotrod Lincoln, hardshell), 73 guests, and 4 robots.
Topics128,030
Posts1,055,428
Members48,422
Apprentice
Apprentice
I replaced the alternator on my 53 with one with an internal regulator alternator. It is a 12 volt system and it seems to be charging a little high. I wired the system as it is explained in this article. http://www.chevelles.com/techref/ftecref14.html
I did this a couple of days ago, and then today I installed a kill switch in the battery negative batery cable. If I turn the kill switch with the engine running to off the engine keeps running, horn works etc. Once I turn the ignition switch off the circuits are all dead as should be. My question is, is this normal or do I have something wired wrong in my alternator conversion? Thanks in advance,
Ralph
Ex Hall Monitor
Ex Hall Monitor
Normal. Everything is feeding off of the alternator when the engine is running. The battery is basically out of the loop unless there's a load the alternator can't meet.
Ralph,
Tiny has been doing great in the alternator department lately, so I won't dispute what he says above.
I didn't know that it would behave that way, but I think that interrupting the negative cable is akin to disconnecting the battery, and I thought this was a near death experience for a alternator equipped charging system.
Stuart
Quote
yep. Don't make a practice out of it as you could fry some alternator wires.
"It ain't a truck if you can't hose out the cab."
You can put a diode in the power line TO the alternator that will prevent the engine from running on with the ignition off.Go to a Napa store and ask for a diode trio for a GM internal regulator alternator.Use one leg of the three,wired in line (ignition power [on/off] to alternator).This should have been done inside the one wire alternator before you bought it.Send me a PM message with your address if you need a diagram.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Riding in the Passing Lane
As far as charging high, put a voltmeter across the battery. It should read close to 14 volts with the engine running & little or no load.
1972 Chevy c10 Cheyenne Super
Ex Hall Monitor
Ex Hall Monitor
One episode of Ice Road Truckers had one of the drivers that lost his battery box & all of the batteries in it & didn't even know he lost it until he got to the end of the 200+ mile run & shut his rig off. His boss wasn't happy at all.
NHRA drag racing rules state that the battery disconnect be installed on the positive wire.So if you run the battery wire from the alt. directly to the battery when the switch in turned off every thing goes dead
Apprentice
Apprentice
Thanks for all the replies. I will install the disconnect in the positive line. Now I have another problem, since I installed the new alternator, I am having an intermittent problem with the igniton going dead. Just acts like a loose wire, some times I can move a couple of wires and it will start. It usually starts and as soon as I let up on the starter switch she dies. Had her out last night and she went dead so I had to run a hot wire from the cigar lighter to the hot side of the ignition and we were off and running again. It has the HEI distributor installed in it. I am going to take the mulit meter out and do some checking today.
Ralph
Are you running the HEI through a resister? The HEI doesn,t use a resister in the system .It should have 12 gauge wire comeing off the ignition switch. If that is the case you probably have a bad ign. switch.
Apprentice
Apprentice
Wrenchbender Ret, Yes it does have HEI ignition,and the resistor is bypassed. That is my thought also, bad ing. switch. The next time it stops on me I will put a test light on ing. switch to conferm.
Ralph
using your reference article.
Quote
The wire that goes from the "BATT" terminal to the #2 terminal is a new wire that you will have to add. You can use a 14 gauge wire.
that should be the DA plug wire from a further 'reference point'
NOT just off the big lug @ the alt.
Jim & Caroline
Apprentice
Apprentice
carolines truck, I am a little confused, OK I understand what you say, I did run the new wire just from the big lug on the Alt. to the #2 post but where should this wire be coming from?
Thanks, Ralph
any place that draws power to the working electrical components of the truck, a way from the alt.
just NOT directly off the big alt lug
read this
http://www.madelectrical.com/electricaltech/remotevoltagesensing3.shtml
Jim & Caroline
Apprentice
Apprentice
Jim, I did run the wire to another point away from the Alt. and don't see any differance. The Alt. is charging good and the truck is starting much better now when hot, turns over well. The ignition has decided to keep working so haven't found what was causing intermittent problem. We will keep on trucking.
Ralph
