1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#1023500 04/22/2014 4:30 PM
1953 3100. I'm putting it back together. At the moment, I can't find my accelerator rod. I may eventually run across it, but for the moment does anyone know where to buy one?
1953 3100
Melbourne, FL
Veteran
Shaanxi #1023509 04/22/2014 4:53 PM
Place a Want Ad in the Swap Meet.
Indicate that you have a 1953 truck 216 engine.
Shaanxi #1023630 04/23/2014 1:46 AM
Sounds like its time to clean up the shop. That's how I find most of my lost parts. smile
Shaanxi #1023632 04/23/2014 2:00 AM
It might be worth a shot to try Jim Carter's and ask someone to look for it in their used parts collection.
Shaanxi #1023742 04/23/2014 3:04 PM
Thanks guys. @52Carl...you got that right, AND get some proper lighting.
Someone offered up one. I'll give it just a few days, and try to clean up the garage.
1953 3100
Melbourne, FL
Veteran
Shaanxi #1023986 04/24/2014 5:12 PM
Go ahead and pick up the new one. Nothing, I mean nothing makes missing parts show up as well as buying a new one. The second most effective way to make a missing part show up is to accuse your wife of throwing it out. The part which you are missing may not be worth the 'cost' of option #2.
Carl
Shaanxi #1024415 04/26/2014 4:41 PM
Ok 52Carl, gets the prize.
I found it. Somewhere along the line, it fell into a box. Soooo, cleaning out the work area and I found it.
1953 3100
Melbourne, FL
Veteran
Shaanxi #1024496 04/27/2014 2:59 AM
There, you see? Sometimes it IS acceptable/productive to post sarcastic, smarty-pants responses. smile
Shaanxi #1024500 04/27/2014 3:19 AM
I used a piece of my old rocker arm oil line for quite some time, I got one from Pre-68 Dave, and eventually found the original. so now I have two that don't fit with the fenton headers...
