0 members (),
133
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | Have a stock 58 235 from an apache, is the stock cam hydraulic or not? Just curious, debating whether I should pull the head to have checked at machine shop or not, running motor was putting in another truck. Also, was the remote oil filter cannister an option? This one has zero filtration device on it. came from long wheel base work truck, 3 speed on column. 235 one barrel carb. THANK YOU | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All truck 235's came stock with a solid lifter cam. That does not mean it couldn't have been changed at some time. Oil filters were an option.
See the USA in your vintage Chevrolet! My Blog | | |
