2 members (2 invisible), 84 guests, and 6 robots.
Topics128,266
Posts1,058,368
Members48,485
#102342 08/30/2007 6:27 PM
Apprentice
Apprentice
My 1952 GMC gauge remains on full with key on. With key off reurns to empty. I took the sending unit wire off the tank and the fuel gauge(KEY ON)WENT TO A LITTLE ABOVE EMPTY ...RIGHT WHERE IT SHOULD BE. WHADDA guys think? bad ground? Terry1218
Terry A. Dudash
Terry A. Dudash
1952 GMC 5-Window 1/2-Ton
#102343 09/01/2007 6:26 AM
Junior Member
Junior Member
i've found that most problems are caused by bad grounds.
#102344 09/01/2007 2:54 PM
Bad sender, which could be only a bad ground. Try a ground wire from the sender to a good ground. When i trouble shoot for grounds i take a jumper to the neg battery. Also seems like your gauge is not accurate. With wire off the sender should read empty, ground the wire and you should read full.
"It ain't a truck if you can't hose out the cab."
