2 members (Hotrod Lincoln, KCMongo), 82 guests, and 0 robots.
Topics128,050
Posts1,055,639
#102290 08/25/2007 7:56 PM
I figured I would get my cancellation part of the turn signal switch to work. I posted some pics to show you how the cams are set up etc. I think they may be wrong. i thought i had them working but not now The signals work but its not aligned right, Can you look at the photos and compare them with your trucks or if someone has detailed drawing of a switch... What does the big screw on the left do????
#102291 08/25/2007 7:59 PM
You will have to go to the gueat book portion of my albumm click on turnsignals ... Thanks peter
#102292 08/26/2007 4:31 AM
That's a beautiful truck, but I can't find your turnsignal pics.
#102293 08/26/2007 4:19 PM
The big screw is just the pivot point/mounting screw for the arms. What do you mean its not aligned right?
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#102294 08/26/2007 4:51 PM
you mean go to the 'album list' to get to the turn sig pics grin
it's together right, so if it's not cancelling, it's because of the fingers on the underside of the wheel, maybe not in the right place, or even missing
