| | | Forums66 Topics128,041 Posts1,055,593 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | I figured I would get my cancellation part of the turn signal switch to work. I posted some pics to show you how the cams are set up etc. I think they may be wrong. i thought i had them working but not now The signals work but its not aligned right, Can you look at the photos and compare them with your trucks or if someone has detailed drawing of a switch... What does the big screw on the left do???? | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | You will have to go to the gueat book portion of my albumm click on turnsignals ... Thanks peter | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That's a beautiful truck, but I can't find your turnsignal pics. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | The big screw is just the pivot point/mounting screw for the arms. What do you mean its not aligned right? Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you mean go to the 'album list' to get to the turn sig pics it's together right, so if it's not cancelling, it's because of the fingers on the underside of the wheel, maybe not in the right place, or even missing Bill | | |
