6 members (9% grade, Shade Baby, UtahYork, Ridgeback, 55shaker, Pre '68 Dave), 116 guests, and 0 robots.
Topics128,108
Posts1,056,565
Members48,448
Page 2 of 2 1 2
Apprentice
Apprentice
Thanks Stuart,
I was testing and it had continuity, I would expect the resistance of the system to change with position of the float just out of the box but I will check it out, I get F reading with the gauge installed at all times wheh ignition is on. I could check the wires, the ground to the tank is fine but I will check the gauge to sending unit wire for further diagnostics.
How ya doin’ doc, haven’t heard from ya for a while.
I don’t know ’55 and I don’t know GMC but I do know ’50 Chevy and here is a link to a couple of things that I ran into when I rebuilt my sender. Now remember this was a 6v system.
“I tested the range and it runs from 1.9 ohms to 38.1 ohms. Couple of pics here, take a look.”
http://rides.webshots.com/photo/2810310490098611668EngTlM
The thread was here if you care to read it.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002823#000000
Hope this helps ya out Paull.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Apprentice
Apprentice
denny: I'm ok but too busy with life, haven't forgotten about you either. What is your mailing address? I will check the resistance again, just go off of the terminals? Do you want to try the 235 in your beast? call me at 708-341-5036. How do you rebuild the unit/
Well Paull my sender was an after market unit, it must have been replaced at sometime in the past. I had to actually make some of the components to replace the broken parts in mine. I spent way too much time on it and should have just bought a new unit. It's just that I'm retired now and on kind of a limited budget. I have more time than money to do these things. If you have a defective unit I really think that the best route to take is to simply order a replacement.
Right now at the top of my list is finding a 4.11 Eaton gear from a '67-'72 3/4 ton so I can at least move along with the traffic.
I am considering a 235 in the future and if the right one comes along for the right price I might just haul it home. Right now I’m planning on rebuilding the original 216 short block this winter.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Page 2 of 2 1 2
