0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've found plenty of post covering putting a spin on adapter on a six but not a V8. I bought a '62 Biscayne with no oil filter at all so this isn't converting from a canister to a spin on. This is putting a spin on adapter where there's been no filter before. What's the process for putting a spin on adapter on a filterless 283?
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I know J.C. Whitney use to sell spin on adapters for replacing cartridge filters on Chevy V-8s...... They always showed 2 different ones. John | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My problem is that I don't see an obvious place where the adapter would mount. I can get the adapters about everywhere but that does me no good if I don't know where it goes. If it currently had a canister filter I'd know where but it doesn't have any filter at all.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Tiny, the only Chevy V8 made without a filter mount was the 1955 model 265. (It used the same canister filter the stovebolt 6 engine had). The oil pressure line to the filter was attached ahead of the intake manifold at the front center of the block, just above the timing cover. The return line went to a fitting in the oil pan, I believe. All the others had a filter mount cast into the block at the driver's side of the bellhousing area. Either a can-type canister filter or a spin-on was used from 1956-up, depending on the year of the engine. I wonder if somebody has swapped a 55 engine into the car sometime in the past? Check the stamped engine ID number on the machined pad ahead of the passenger's side cylinder head. If it is a 55-year 265, it's a scarce engine, worth something to somebody who's doing a period-correct restoration on a 55 car or truck. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I think I found it Jerry. I found a huge honking thing hanging down toward the aft driver's side of the block. Looks like it'll hold two or three quarts of oil. It's half again or double the size of the canister I put on my '38. If that's indeed the filter I will be putting on a spin on adapter for sure. Thanks my man.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Yep, you found it- - - -about 4" in diameter and nearly a foot long! The O ring gasket above the canister has a nasty habit of sticking in the groove, so if you decide to use the original filter element, take an ice pick and pry the old gasket out. I've found two, and sometimes 3 canister gaskets stacked on top of each other on some oil changes back in the dark ages! Jerry
| | | | | Joined: Apr 2013 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 144 | I like the looks of the old canister filters, but then again, I like most anything "old". You can still buy the filter that goes inside the canister, they're about 10 bucks. I have a '56 265 that has the spin on adapter, and I also have a '58 235 truck motor with no oil filtration at all. the canister oil filters are worth something to someone doing a resto. How much is the question. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have an adapter on order. I'll keep the canister. It'll be easy to return it to original if I ever decide to do that.
