| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | O.K. guys what do I have here?
casting # 3836233
Number on the pad buy the distributor. #06859 IO55Y
TIA.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | I get a 55-57 235, from the casting number and from the serial number: 136 HP and a Powerglide...that makes it from a car and has hydraulic lifters.
Steve H
| | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | Thank you Steve for the reply. I'm going to assume since the head doesn't have a 848 casting number which started in 1956, that I have a 55 engine. If the head hasn't been changed in the last 50 some years.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are locations of date casting codes. That will ID the date of the head - the "848" head had a long run and was often used as a replacement head on any 53 and new 235 engine (a replacement head from GM or from a donor engine). | | |
