2 members (Steveoreno, 1 invisible),
126
Mod | | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | My panel has 700-17 tires and split rims on it. What size tire would that be in a modern radial, I'm missing three rims so instead of finding some I thought I would go buy all new tire and rims
So I need to know what size of black steel rims and radial tires to look for
1950 one ton panel, 1959 half ton apache
| | | | | Joined: Sep 2010 Posts: 1,732 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,732 | Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | On my 1 Ton I have 16 x6 rims with LT750 x16 radial tubeless tires. | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 |
| | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | Where did you buy the tires and rims. I can't seem to find any on web. Also do you think the stock hub caps will fit those rims
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Try Ford F250/E250 wheels.
1997 and older F250
All Ford E250/350 vans.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I believe you mean 97 and older
Bill Burmeister | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Just fixed it.
Dislexia of the keyboard. | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | Do you think the old chevy hub cap will fit them
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Mine are Yokohama tires and I don't know if they are still made. You can also use trailer rims, OEM style. I think Dexter is the name. Officially they are not rated for anything but trailers but they are heavier than the automotive ones. They don't have any spaces between the center piece and the outside. One of the trailer suppliers has baby moon (showing my age) type hubcaps. I use these on the front and I have nothing on the back. They are difficult to get on. The real hubcaps can be used by installing clips.
