3 members (sron48, 1955 1 Series, Southerntruck), 37 guests, and 10 robots.
Topics128,010
Posts1,055,308
Members48,419
#1021280 04/13/2014 12:41 AM
O.K. guys what do I have here?
casting # 3836233
Number on the pad buy the distributor. #06859 IO55Y
TIA.
Brian
Brian
1955.2 3100 Truck
55shaker #1021283 04/13/2014 1:19 AM
I get a 55-57 235, from the casting number
and from the serial number: 136 HP and a Powerglide...that makes it from a car and has hydraulic lifters.
Steve H
Steve_H #1021875 04/15/2014 5:17 PM
Thank you Steve for the reply. I'm going to assume since the head doesn't have a 848 casting number which started in 1956, that I have a 55 engine. If the head hasn't been changed in the last 50 some years.
Brian
1955.2 3100 Truck
55shaker #1021891 04/15/2014 6:05 PM
Here are locations of date casting codes. That will ID the date of the head - the "848" head had a long run and was often used as a replacement head on any 53 and new 235 engine (a replacement head from GM or from a donor engine).
