1 members (moparguy), 39 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Going thru the pile of stuff that came with the truck.
So far I've been unable to identify these two items:
#1: Looks like a crossmember / mount of some kind. My driveline is all mounted complete and nothing I see matches. Link:
Mystery part #1
For #2, it a steel rod, square section, about 2ft long, with a thumbscrew and spring in one end,and the other a small bolt. Link:
Mystery part #2
I have a couple of close-up pix in there too.
Any help would be greatly appreciated.
NHluvstruck...
1951 3100 5-window,.sold, regretted
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Welcome to the site. It helps if you give us a year.
#1 appears to be shaped like an AD grille but it is hard to judge the size of it from here.
I don't think #2 is a truck part unless you have a pretty early truck.
Without knowing what year or model you have, I can only say what it does not fit. It does not fit any 1947/1955 Chevrolet or GMC 1/2 ton trucks and probably any other series either. The crossmember looks like a newer model, 70's, 80's or newer…………g
#1 looks like a trans cross member for a later model. Maybe the PO was planning to upgrade the tranny. #2 I have no clue.
Its a 51 half-ton....just updated my signature.
The PO did have a SBC he was intending... I didnt get it as I want to keep the six for now. Will try to add some better pix with tape measure to the photobucket.
Thanks!
NHluvstruck...
