5 members (1955 1 Series, 49nut, rfs56trk, Eisenholtz, tclederman), 88 guests, and 0 robots.
Topics128,046
Posts1,055,618
#1020658 04/10/2014 3:05 AM
Here's a question for the experts. I installed a new dual reservoir MC & bled the brakes. Jacked it up & supported on jack stands. The drivers rear stopped very well, but the passenger rear didn't. Figured all I had to do was to adjust the shoes in the passenger rear a bit. It has the original 4:11 posi rear gears. One thing I did notice is that when the drivers rear tire stopped, the passenger rear wheel speed increased. Is this OK and has anyone run into this before? I realize there is a primary drive wheel, even with a posi, and I assume this is only caused by the tires being up in the air? Took the drum off & everything seems to look & function as designed.
Jim1953 #1021035 04/11/2014 7:22 PM
bump
1951 1 Ton Completed
Jim1953 #1021072 04/11/2014 11:29 PM
Since you have it off the ground adjust the shoes up to where they drag about the same and you should be fine. Sounds like the rear is doing its job.Larry
58 gmc 100 with 350 sbc
Jim1953 #1021129 04/12/2014 3:07 AM
Gas Pumper
Gas Pumper
Yeah, Jim.. what I do is exactly what Larry suggested. Make the brake shoes touch the drums just enough to hear them scrape as you turn the wheel. Then get someone to hit the brakes for you and both wheels should stop about the same.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Jim1953 #1021171 04/12/2014 1:59 PM
If this is a 1953 rearend, I don't think that it would have a posi-traction setup. If it does, maybe there is some weird interaction going on here. I would have someone push on the brakes while you manually try to turn each rear wheel.
Jim1953 #1021184 04/12/2014 2:43 PM
Is it a 1953 1/2 ton enclosed drive-shaft rear-end?
Did you install new brake shoes, and/or turn the drums?
Jim1953 #1021297 04/13/2014 2:16 AM
As far as I know it is the original torque tube driveshaft & rear end. It is a Posi. I'm assuming that the torque forces were divided between the two wheels & when the one stopped the other sped up to carry the load. Also found that the passenger rear had a sticking wheel cylinder. That is now fixed & the brakes are AWESOME! Good to know that the suicide MC is gone & some brakes will be there even if half of the system fails.
Jim1953 #1021304 04/13/2014 2:36 AM
There was no Posi version of the torque tube rear. Positraction became an option on 1/2 tons in '59, using a Spicer 45 axle w/3.92:1 gear. You mention in your first post that when the left wheel was stopped, the right wheel would turn faster. This is normal for an open differential, a Posi differential would not allow you to do this, it would have locked both wheels together.
Bill Burmeister
