8 members (Jims46, 2-Ton, Otto Skorzeny, tclederman, Bill Hanlon, Millenimech, dt235sd, greenie-reddy),
131
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 6 New Guy | | New Guy Joined: Apr 2013 Posts: 6 | Has anyone done front drum to disc brakes on 1941-46 GMC or Chevy? Have found 6 lug rotor kit that will work. The big question is the brake booster to go in frame. Found boosters for 1947 in frame can this be used with some modification . Hope someone can help me make my ride a safer ride. My ride is a 1945 GMC. Long box. | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | use a 7" booster you will need a duel master cyl for disc brakes. the hole in the floor will have to be moved so you can fill it. if you are using the stock running gear the trans mount will have to be mod.+ brake lines | | | | | Joined: Sep 2010 Posts: 1,722 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,722 | I used a 1 inch bore m/c. It stops fine without a booster.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
