| | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 6 New Guy | | New Guy Joined: Jan 2014 Posts: 6 | I am running 17.5" rims on the rear and still have the old 17" on the front. I need new tires and took my extra rims to a tire dealer who told me the taper on the inside of the rim might cause the tubeless tire not to seal so well. I have to do some work to clean up the 5 17.5s and am looking at going to 16" rims but need the hubcap clips and I also need the tire to fill up the wheel well - the tire needs to be 30.5" tall.
I don't want to go chrome, black steel will do just fine. This is an old Falstaff beer truck and I want to paint it and fix it up but not hot rod it. Any experience with rims and tires? 17.5 tires are expensive. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 17.5" wheels are a god option if they fit (sounds like it) 19.5" is also a very good option and with 8R19.5 tires will fill the wheel wells at about 31-32"
16" may or may not fit over the brakes and I think looks on the small side, or if you get tall enough tires they're wide and also look out of place. | | |
