0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | I have searched and have not found the answer so I thought I would ask, on a 1953 3100 do the OG 16" 6 lug wheels have six or three hubcap clips? Thank you.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Original wheels in '53 had 6 clips. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thank you Cletis, do you know which year/s used the three clip 16 inch wheels?
| | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | MtnMike I have looked into the same question for my 57 3100 and have determined that 55 2nd thru at least 1959 had 3 clips. delky dave
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | Will the same hub caps fit on both rims . My 3 clips have holes so extra clips can be added ...My 55 1st has 6 clips ....
" STUCK IN THE '50'S "
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, the hubcaps fit either. According to our late GM wizard, W D Foster, the wheels with nubs were phased in over the '61 model year. | | |
