2 members (Phak1, Bill Hanlon),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,129 Posts1,056,360 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Good morning. My son and I recently picked up a 1952 3100. As you can see, the prior owner(s) have attempted to do "something" to the exterior. I'm not sure if all the original paint was removed and then some sort of primary applied or if it was just painted over. There is visible surface rust coming through. There is also a lot of filler in places that was not sanded out very well. We are not doing a restoration, just want to get it up and running hopefully as a daily driver. I may try to take off bed, fenders, etc to enable a taking care of the nooks and crannies. We can't afford media blasting and don't have the facilities to do anything at home. I need advice on how to remove the paint currently on the truck and then put on some sort of primary/rust preventing agent and then maybe some sort of flat top coat. Do I get some sort of electric sander/wire brush? Once down to the metal, do I fine sand or just add rust prevention directly on top? Also, we are going to have to attack this piece meal. Maybe one fender then a month later another fender, then maybe a door, etc. If you could provide links to good videos and/or links to product to use, it would be greatly appreciated.
Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | might start with a good chemical paint stripper, once you get the majority of the finish off, a sander should take care of getting it to fairly clean metal, after which epoxy primer would be best to preserve it and prevent rust, especially doing the pieces a bit at a time
Bill | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Thank you. Would something like an orbital sander work? What grits would be best? Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, could do if that's what you have - I'd try 80 grit once you've got rid of the bulk of the paint, it'll leave the best 'tooth' for a primer
Bill | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Hi Boys,
In my opinion, that body isn't that bad overall. Yes, the PO didn't finish off the filler very well, but it looks like the sheet metal was sanded and then covered with spray can primer. The rust on the rear fender is typical of metal sanded down to bare metal and given a couple coats of primer and then left in the weather. without sealing it will always rust in a few months.
Anywhere the original paint is still in place, don't take it off, use it as a base.
I would wet sand the whole thing with 220 or 330 grit. I would expect you would find 80% of the body ready for nothing more then another coat of primer. Even that rear fender will clean right up with wet sanding.
5 gal bucket of warm water with a little bit of something like Spic & Span or simple green and keep the area wet and rinsed with the hose.
Then evaluate where the bad spots are.
Note the areas you sand have to be dried and covered with primer within a day to prevent surface rust. | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Even better yet! Thanks Jim. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | IMHO, I'd avoid the chemical stripper. Too many opportunities for some to soak into a crevice and not get rinsed out and neutralized properly. Then after you have invested all the work in primer/paint (even if you give it a budget paint job), it would be a shame as you sit back and enjoy the fruits of your labor to see the paint bubbling up in a crack due to some chemical stripper left behind.
Start out w/ 80 grit and see how deep the primer goes. It may surprise you how much paint is actually on there. I used chemical stripper on a truck once. Even after what I thought was an adequate wash down to neutralize, the paint let go about 3 months later. Only thing I could ever deduce was that it was the stripper in the crevices. This was on a 1963 GMC Truck. | | | | | Joined: Feb 2014 Posts: 173 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 173 | Yeah, chemical would have been my last choice. I have a tendency to spill things like that as well as "fling/drip" issues. Ron and Ryan Hill 1952 Chevy 3100 | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If you're looking at mechanical stripping i.e. sanding, then look for a regular circular disk like a grinder to remove the majority of the old paint. It's much more aggressive than a DA. It doesn't take as long and if more than one coat of paint is on your truck can cut the time in half compared to a DA. Plus if you use one of those old 20lb 7" grinders you can skip the gym weights routine for the week!
Also if you find multi layers you can use 24 or 36 grit to cut and break up the top layers stopping before breaking through to the metal then switching to 80 or 100 for the rest. Somewhere around this step I switch over to DA.
To get the pitted area you can use phosphoric acid (Ospho, Picklex, etc) but make sure to neutralized it properly if using epoxy primer.
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Just remember coarse sand paper will remove metal fast. Only use an oscillating type sander DA etc. Sand blast, or chemical.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | On the other hand, if you are not going down to bare metal in all areas, use the current layers of primer, paint, etc as your substrate. HAND sand using sanding blocks of different lengths using 80 grit to start. Once its very uniform (not in color, but in smoothness) use body filler to smooth those low areas, then hit the whole thing with epoxy primer.
What you are doing is rather than spreading a 1/8" skim coat on everything as most people do, you are using your current substrate as the first round of filler. I have done several entire trucks and have no mechanical, electrical, pneumatic sanders at all. Once you master the art of the feel of the work, you will be able to fine tune your technique. At that point, if you feel mechanical tools are still necessary, get out the wallet. That was my plan years ago, then discovered no need at all to get the tools!
There are other considerations. For example, anywhere you apply heat for welding up damage, your substrate will be compromised and you will need to sand to bare metal in those areas. I don't keep any old substrate myself, I sandblast everything, but many people do the above technique with dazzling results. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Norton paint stripper disc for angle grinder. Google it. Eats paint like nobody's business , but doesn't touch the metal. Works great on bondo too.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Norton paint stripper disc for angle grinder. Google it. . . . I Googled it - which one is it? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I prefer this one for a 7" grinder. Also sell a 4.5" version. Poly-X stripping disk | | |
