0 members (), 139 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Just finished rebuild on 84 truck 350 four bolt main. Runs great but...... 2 bolt holes at lower front passenger side edge near fuel pump will pump out oil on high rpm. Didn't do this before rebuild. Is it ok to plug these or does something go here that I lost? These same holes in my other truck aren't plugged and never leaked. What did I do wrong?????
Don
You should put a 3/8" bolt in the top hole with some sealer on it. If you slide a screwdriver into the hole you will find that it goes into the passage for the fuel pump pushrod.
That bolt needs to be really short- - - -like 1/2" long or so. Don't let it come into contact with the fuel pump pushrod!
Buy some Permatex Gasket maker in a tube....non-hardening formula. Cost is less than $4 bucks. Brown goopy stuff and it sticks to everything. Take the bolts out and clean them as well as the holes in the block. Rub a small amount around the bolt threads, just enough to cover the threads. Re-install the bolt and torque to specification. That should stop the leaks.
1970 VW Beetle
Sir Searchalot
Sir Searchalot
As said, there is a hole to put a long bolt in to hold rod up while installing pump, then replace with short bolt. They never needed any sealer in my experience, wouldn't hurt probably. A copper washer will work if you don't like sealer in there. Post picture of other leaker? Are you sure both leak or just one and spilling onto other? I think you will find the bottom hole is blind. You will find that when you put in a short 3/8 bolt in the top hole, the leak will go away as stated by Don and Jerry.
"These same holes in my other truck aren't plugged and never leaked"... ????????what engine? What year? is it FI? Better double check that!!
I apply some red rtv to the threads on a short bolt and screw it into the tapped hole, just as others above have stated.
Here's more discussion on this topic from the Team Chevelle Website:
Originally Posted by Dean;2841745
A long enough bolt through that hole acts as a set screw into the side of the fuel pump push rod to hold it UP while changing the fuel pump.
Just don't forget to plug the hole with short bolt when done.
I bought a pickup one time that had nothing in the hole and oil was being blown back all over the motor by the coolant fan.
Links here ----> thread link photo
